Predeterminado Toyota Dyna
Hola
Alguien tiene antecedentes o el modelo de una caja de toyota Dyna, para adaptarsela a un Land Cruiser.
Facundo
Engine
Type 4 cylinder in-line OHC
Displacement (cc) 2779
Bore and Stroke 96.0mm x 96.0mm
Compression Ratio 22.2:1
Max. Power (HP/rpm - DIN) 80,5 Hp @ 3600rpm
Max. Torque (Nm/rpm - DIN) 185Nm @ 2400rpm
Model 3L Diesel Engine
Maximum Engine Revs 4100rpm
Oil Capacity 6.0 litres
Coolant Capacity 9.4 litres
Combustion System Indirect injection
Cooling Fan Fluid coupling
Standard Transmission
Gear Ratios
1st 5.146
2nd 2.780
3rd 1.509
4th 1.000
5th 0.830
Reverse 5.035
Model
R452 Manual Transmission
Type
5 speed all-synchromesh, 1 reverse slide mesh, floor change
Suspension
Front:Shock Absorber Hydraulic double acting telescopic
Front:Span x Width 1100mm x 70mm
Front:Spring Semi-elliptic leaf spring
Front:Thickness x Leaves 8mm x 1 + 9mm x 3
Front:Type Rigid axle
Rear:Shock Absorber Hydraulic double acting telescopic
Rear:Span x Width 1210mm x 70mm
Rear:Spring Semi-elliptic leaf spring
Rear:Thickness x Leaves 8mm x 2 + 6mm x 1 + 14mm x 2
Rear:Type Live rigid axle
Brakes
FR Lining Area 220cm squared asbestos-free
Front 258mm ventilated disc with floating single cylinder caliper
Park Brake Internal expanding mechanical brake operating on propeller shaft
Rear 290mm internal expanding drum with two leading shoes
RR Lining Area 644cm squared asbestos-free
Service Brakes Hydraulic with 11" vacuum booster, tandem master cylinder, Load Sensing Proportioning and Bypass (LSP and B) valve
Wheels/Tyres
Front Tyre 6.00-15-8PR LTx2
Front Wheel 15 x 4.5K
Rear Tyre 7.00-15-8PR LTx3
Rear Wheel 15 x 5.5K
Model Code
Model Code LY211R-TBMFSQ3
Body
Style Cab/Chassis, Single Rear wheel
Cab
Internal Sunvisors Driver and outboard passenger with ticket holder on driver's side
Rear view mirror Two external west coast type, plus one internal std type
Seating Capacity 3
Seats Fabric faced seats, fore-aft & backrest adjustment on driver's seat, bench passenger's seat, backrest folds into parcel tray, 2 x 3 point ELR seatbelts, 1x2 point lap belt
Ventilation Four-speed fan with floor and dash ventilators and heater/demister. Roof ventilator
Windscreen Glass Tinted laminated
Windscreen Washer/Wiper Two preset speeds and intermittent
Steering
Ratio Variable 22.2:1 to 25.4:1
Turning Circle (kerb to kerb - m) 10.2
Turning Circle (swept - m) 11.4
Type Manual recirculating ball and nut
Dimensions
Cab End to Rear Axle (mm) 2035
Front Overhang (mm) 1020
Front Track (mm) 1410
Overall Height (mm) 1960
Overall Length (mm) 4610
Overall Width (mm) 1695
Rear Overhang (mm) 1075
Rear Track (mm) 1360
Wheelbase (mm) 2515
Weights/Capacities
* Subject to State regulations and tow bar design
Front Nominal Kerb Mass (kg) 925
Max Towing Capacity with Trailer Brakes (kg) 1800*
Max Towing Capacity without Trailer Brakes (kg) 400*
Rear Nominal Kerb Mass (kg) 365
Total GVM (kg) 3350
Total Nominal Kerb Mass (kg) 1290
Instruments
Meters and Gauges Speedometer, tachometer, odometer, trip meter, fuel gauge, coolant temperature gauge
Warning Lamps and Buzzers Brake system warning light (parking brake reminder, low brake fluid level warning, low vacuum warning), battery discharge warning light, low oil pressure warning light, low engine oil level warning light, timing belt replacement warning light,
Warning Lamps and Buzzers. fuel filter warning light and buzzer, clogged air cleaner element warning light, glow indicator light, exhaust gas temperature warning light
Standard Equipment
Equipment Front Ventilated Disc Brakes, Five Speed Slick Shift Transmission, Cyclone Air Cleaner, Tinted Laminated Windscreen, Intermittent Wiper/Washer, Sculptured Semi-Sealed Halogen Headlights, AM Electronically Tuned Radio, Fabric Faced Seats
Equipment. Door Pockets & Armrest (L&R, Soft Feel Steering Wheel and Gearknob, Assist Grips for Driver(1) and Passenger(2), Roof Ventilator, Trip Meter, Instrument Light Rheostat, 3 Cup Holders and Map Pocket in Seat Back, 2 Front Seat Headrests,
Equipment.. Lockable Fuel Cap Asbestos-Free Brake Lining, Air Cleaner Clog Warning, Fuel Sedimenter, Tachometer
Optional Equipment
Optional Air Conditioning
Electrical
Alternator 50A, 600W
Battery 12V 75D31R
Capacity 56Ah @ 5 hour rate
Starter 12V, 2.0kW
Type 12 Volt
Axle
Differential Ratio 4.875:1
Front Reverse Elliot I-beam axle
Front:Capacity 1800kg
Rear Semi-floating rigid axle, single speed hypoid differential gear
Rear:Capacity 2300kg
Clutch
Control Hydraulic action
Diameter 236mm
Lining Area 261cm squared
Type Single dry plate clutch
Chassis
Chassis Width 800mm
Dimensions: Max Height (mm) 131.4
Dimensions: Max Width (mm) 50
Dimensions: Min Height (mm) 91.4
Dimensions: Min Width (mm) 50
Type Ladder shaped tapered channel section
Fuel System
Air Cleaner Cyclone air cleaner
Fuel Capacity 60 Litres
Injection Pump VE Rotary distributor type with hydraulic automatic timer and centrifugal govenor
Water Separator Sedimenter with fuel prefilter
Gracias por la info.
¿Sera muy complicado meter entremedio de mi transfer y mi caja una de estas cajas.?
Asi ganaria Overdrive y reduccion :D
Estoy hablando de una Caja 4x2
Preguntale al P.Suarez dado que hizo un tandem asi, depednerá seguramente del largo de cardan que vaya quedando hacia atrás. Tal vez teniendo alguna dimensión de la caja a instalar podría verse :?:
Predeterminado Caja ..
Ña .. eso si me parece de los más bellaco de hacer.. aunuqe nada es imposible .. si hablia que pensar que esa 1ra de 5.14 es barbara ..
Ahora yo me ahorro lios y meto los gears reducidos para el transfer que venden en Man a Fre ..
A T X
Avatar de A T X
"uno" de los principales temas es el acople de los ejes entre cajas, ya sea por el tema de diametro de los rodamientos de entrada, compatibilidad entre estos diametros como para poder RE-fresar estrias a nuevas y cosas de ese estilo..........yo creo que por ahí va el tema de la complejidad ya que espacio y largo , yo creo que a tu TLC (XXL) le sobra :D .
y que paso con la etapa reductora de la 203??......no te gusto? algún drama? o te estás calentando por reducción y Over drive al mismo tiempo...Golozo. :D
ATX-4X4. . . . . .Mandy
TODOS los datos de Land Cruisers, lo definitivo. JPVM General 4WD 14 07-08-2009 19:45:13
caja toyota dyna con quinta y freno de mano MAÑOSO 4X4 Venden - Partes y accesorios para 4X4 2 04-07-2006 14:14:11
culata toyota dyna B.... MAÑOSO 4X4 Compran 12 25-05-2006 16:38:21
2005 TWISTED ANDES JAMBOREE - Promo Gonzalo Bravo Paseos, Raids, Competencias y Eventos 4x4. 447 30-04-2005 02:59:37
La franja horaria es GMT -3. Ahora son las 07:00:28.
