Antiguo 24-11-2013, 16:37:30   #1
Predeterminado Controlador de electro 2 vel Dakota Digital
Vendo controlador programable Dakota Digital.
Se programa la temperatura de partida y parada de hasta dos electros o dos velocidades de electro.
Esta nuevo, sin uso.
$90.000
The PAC-2750 was designed for the ultimate in flexibility and to be a simple add-on in any application using an electric fan. Included is a 70amp relay, enough for even the most power hungry of cooling fans. Fully programmable, the PAC-2750 will work with your existing water temp gauge, operating from the temperature sending unit already installed. A dedicated sending unit can be installed for applications without a water temp gauge. OBD II compatible vehicles can obtain the engine temperature from the ECM with the use of a BIM-01-1, purchased separately.
When used in conjunction with BIM-compatible Dakota Digital instrumentation or a BIM-01-1, a single cable transfers speed and temperature data to the PAC-2750 allowing the fan to be shut off at an adjustable highway speed!
The PAC-2750 features fully programmable “fan on” and “fan off” temperatures to suit any application or personal preferences. The PAC-2750 has the capability to leave the electric fan operating after the engine has been shut down for a user adjustable time. The PAC-2750 offers a full digital LED readout for displaying temperature readings and maintaining simple installation. A second relay is required for dual fan or two speed fan operation.
Última edición por Gonzalo Bravo fecha: 24-11-2013 a las 19:55:00
Antiguo 25-11-2013, 13:39:34   #2
Predeterminado Re: Controlador de electro 2 vel Dakota Digital
$90.000
A todo esto, es el modelo nuevo, el antiguo se reconoce por la pantalla azul.-
Antiguo 25-11-2013, 16:43:44   #3
Mac
Gonzalo
Te envie PM
Antiguo 25-11-2013, 16:44:13   #4
Diablo
Empezado por Mac Ver Mensaje
Gonzalo
Te envie PM
Excelente....
Antiguo 25-11-2013, 23:28:09   #5
Vendido.......
La franja horaria es GMT -3. Ahora son las 07:48:25.
