Venden - Partes y accesorios para 4X4 Espacio para avisos de venta (de caracter no comercial) de partes y accesorios para 4x4. Todo mensaje que no tenga que ver con el tema será eliminado sin previo aviso. |
Vendo controlador programable Dakota Digital.
Se programa la temperatura de partida y parada de hasta dos electros o dos velocidades de electro. Esta nuevo, sin uso. $90.000 The PAC-2750 was designed for the ultimate in flexibility and to be a simple add-on in any application using an electric fan. Included is a 70amp relay, enough for even the most power hungry of cooling fans. Fully programmable, the PAC-2750 will work with your existing water temp gauge, operating from the temperature sending unit already installed. A dedicated sending unit can be installed for applications without a water temp gauge. OBD II compatible vehicles can obtain the engine temperature from the ECM with the use of a BIM-01-1, purchased separately. When used in conjunction with BIM-compatible Dakota Digital instrumentation or a BIM-01-1, a single cable transfers speed and temperature data to the PAC-2750 allowing the fan to be shut off at an adjustable highway speed! The PAC-2750 features fully programmable “fan on” and “fan off” temperatures to suit any application or personal preferences. The PAC-2750 has the capability to leave the electric fan operating after the engine has been shut down for a user adjustable time. The PAC-2750 offers a full digital LED readout for displaying temperature readings and maintaining simple installation. A second relay is required for dual fan or two speed fan operation.
Última edición por Gonzalo Bravo fecha: 24-11-2013 a las 19:55:00 |
#2 | |
![]() Cita:
#3 |
Gonzalo
Te envie PM Saludos |
#5 |
Vendido.......
Compartir en Redes Sociales |
