#11 |
cuanto y como es un rodaje apropiado.
Saludos,Esteban sainz. |
#12 |
BUSCAR, NEWBIE
BREAK-IN All new gear sets require a break-in period to prevent damage from overheating. After driving the first 15-20 miles it is best to let the differential cool before proceeding. I recommend at least500 miles before towing. I also recommend towing for very short distances (less than 15 miles) and letting the differential cool before continuing during the first 45 towing miles. This may seem unnecessary but I have seen many differentials damaged from being loaded before the gear set was broken-in. I also recommend changing the gear oil after the first 500 miles. This will remove any metal particles or phosphorus coating that has come from the new gear set.
#13 |
Gracias a todos, creo que pondré Yukon, ahora el siguiente paso es quien las instalara, dado que este punto es critico alguien podría sugerir algún Taller en función de la experiencia...??? Gcias.
#14 |
Domingo Medina me imagino.-
#15 |
