Antiguo 23-09-2014, 16:48:27   #1
Kukeen
Edad: 30
Arrow Especificaciones de caja de cambio
Hola amigos.
Bueno el propocito de este post es por una caja de cambio que tengo que buscar sus especificaciones, ya sea las marchas, tipos de sincronizadores, planos etc... bueno me diriji aca por la simple razon que tanto buscar, varios de los usuarios usan la caja que busco... esta es una GM 6273212, creo que es de un camion chevrolet, el modelo no lo se.
Bueno amigos si me pudieran ayudar se los agradeceria mucho.
Kukeen está offline   Responder Con Cita
Antiguo 23-09-2014, 20:32:53   #2
yako
Predeterminado Re: Especificaciones de caja de cambio
Estimado Kukeen hola, busque un poco en internet GM 6273212 encontre estos dos links , espero aportar un poco con este dato para que otra persona busque mas facil el modelo y lo que necesitas.
http://www.vanderhaags.com/detailview.php?part=24243928
6273212GM CH465 Transmission
Es esta tu caja de cambios ?
http://www.novak-adapt.com/knowledge/sm465.htm
The Novak Guide to the
GM Muncie SM465 Transmission
For a video version of this article, click here
The SM465 is an outstanding, heavy-duty truck transmission designed and used in ½, 3/4 and 1+ ton trucks. The SM465 was made by General Motors from 1968 to 1991. They are found primarily in GM and Chevrolet trucks, Blazers, Suburbans and many other models falling under the 1/4-ton to 1-1/2-ton platforms.
The 465 is an intellegently designed and very well-built transmission and remains easy to locate and generally inexpensive to buy and maintain. The strength, relatively short size and the gearing of the transmission make it a good choice for a variety of on-road and off-road situations. It has a very good set of road manners contrasted by its enormous off-road brawn.
The "SM" in the transmission's designation stands for Syncrho-Mesh, in the tradition of other GM gearboxes. It is also referred to as the CH-465 or CH465 by factory literature.
Identification
The SM465 is a top loaded, top shifting truck style transmission. This transmission is 12 " long and features a cast iron top cover that is retained by eight bolts. The SM465 case is of *cast iron. The case itself is generously ribbed both vertically and horizontally.
The SM465 has a 1-1/8" diameter, ten spline input shaft that has a stick-out of 6-1/2" from the front face of the transmission. The pilot tip is ~19/32" in diameter. The front bearing retainer flange measures an unusually large 5-1/8" in diameter and the bearing retainer tube is 1-3/8" in diameter. The front bolt pattern is the consistent GM Muncie / Saginaw four-bolt pattern as found on GM bellhousings and transmissions from the 1940's through the 1990's.
Features
The 465 enjoys a very low compound gear at 6.55:1 and as such it is a popular choice for those wanting a very low crawling gear.
The SM465 features power-take-off (PTO) ports on the passenger and driver sides of the case.
The shifting pattern for the 465 is in the standard "H" pattern with reverse gear being to the right side, and down.
SM465 Versions
There are three principal versions of the SM465, each based on the era and configuration of the transmission. There is no known mechanical superiorities to either earlier or later versions.
Earlier SM465
The earlier era of the SM465 include the 1968 - 1978 transmissions. There were both 2wd and 4wd versions. Internally, they are identical to each with the exception of the transmission mainshaft. The 4wd version of this mainshaft (or "output shaft") has a 10-spline output with a 2-5/8" stickout and an accompanying 4wd adapter housing. The 2wd version has a 35-spline threaded mainshaft compatible with a driveshaft yoke, and accompanying 2wd style tailhousing.
yako está offline   Responder Con Cita
Antiguo 23-09-2014, 20:40:31   #3
yako
Parts for the
SM465 Transmission
The SM465 is arguably one of the greatest four-speed transmissions ever built, and reconditioning one is a worthwhile project.
The Kit
Our master rebuild kit has been assembled for our customer's rebuilds as well as our own. It is the most complete kit we've seen anywhere and features all the consumable and wear item components.
Our kit standardizes the SM465 thrust washer and endplay and we recommend that you use the supplied shaft bushings with the supplied thrust washer for simplicity.
There are two versions of our rebuild kit, each compatible with all 2wd, 4wd and conversion 465's:
  • The first and most common kit is for 1968-1987 versions as well as 1988-1991 versions with the narrower .68" front bearing.
  • The second kit is for the 1988-1991 version - typically with the aluminum top cover - with the wider .83" front bearing. The only way to know this version is to remove the front bearing retainer and check for a #211 bearing or to remove it and measure its width.
Rebuild Requirements
It is very common for our customers to do top-level rebuild work, using good methods and by following our included instruction guide.
We suggest the rebuilder have access to a set of snap ring pliers, a bearing puller and a hydraulic press.
Kit 465MR-1, master rebuild, SM465 transmissions, 1968-1987 versions Part #: 465MR-1 Weight: 10.23 Price: $229.00 Buy: All bearings, synchronizer rings, journal bushings, snap rings, thrust washers, seals, gaskets and instruction guide
Kit 465MR-2, master rebuild, SM465 transmission, 1988-1991 with wide front bearing Part #: 465MR-2 Weight: 10.50 Price: $247.00 Buy: For 1988-1991 versions with .83" wide, #211 front bearing (not .68" bearing). Contains all bearings, synchronizer rings, journal bushings, snap rings, thrust washers, seals, gaskets and instruction guide
Other Components
Essentially all parts for the SM465, including gears, shafts, factory adapters & tailhousings, retainers, etc. are available new and affordably so. Our parts ordering module is provided below. For anything not shown, contact us.
Antiguo 23-09-2014, 20:41:40   #4
yako
Click on any item description in blue below to expand its details for purchase. You can use your browser's Back button to return to this page and your cart items will remain.
For your reference, all asterixed * items below are included in our master rebuild kit, above.
Items indicated with a "" are not available singly, but are included in the Small Parts Kit, #A below.
A. Kit, small parts *
B. Kit, mainshaft journal bushings *
1. Retainer, bearing, front input
2. Gasket, front input bearing retainer *
3. Seal, front input *
4. Ring, retaining, front input shaft to bearing *
5. Ring, retaining, front input bearing to case *
6. Bearing, front input *
7. Shield or slinger, front input *
8. Shaft, front input (aka, input gear or clutch shaft)
9. Ring, clip, input shaft to mainshaft pilot rollers *
10. Bearings, needle rollers *
11. Ring, synchronizer, 3rd to 4th gear *
12. Slider, clutch, 3rd / 4th gear
13. Ring, clip, input shaft to mainshaft pilot rollers *
14. Spring, synchronizer hub, 3rd / 4th *
15. Hub, synchronizer, 3rd / 4th
16. Spring, synchronizer hub, 3rd / 4th *
17. Keys, synchronizer hub, 3rd / 4th *
18. Assembly, syncrhonizer hub, 3rd / 4th
19. Ring, synchronizer, 3rd to 4th gear *
20. Gear, 3rd
21. Bushing, mainshaft journal, 3rd gear *
22. Washer, thrust *
23. Gear, 2nd
24. Ring, synchronizer, 2nd to 3rd gear *
25. Bushing, mainshaft journal, 2nd gear *
26. Shaft, main
27. Spring, synchronizer hub, 1st / 2nd *
28. Hub, synchronizer, 1st / 2nd
29. Spring, synchronizer hub, 1st / 2nd *
30. Gear, reverse, sliding clutch
31. Keys, synchronizer hub, 1st / 2nd *
32. Assembly, synchronizer, 1st / 2nd
33. Bushing, mainshaft journal, 1st gear *
34. Pins, 1st gear
35. Gear, 1st
36. Washer, thrust, improved aftermarket version*
37. Bearing, rear output *
38. Ring, retaining, rear output bearing to case
39. Ring, retaining, mainshaft to rear output bearing*
40. Bearing, roller, countershaft front *
41. Ring, retaining, countershaft front bearing *
42. Washer, spacer, countershaft front
43. Gear, countershaft drive
44. Washer, countershaft spacing *
45. Ring, retaining, countershaft spacing *
46. Ring, retaining, countershaft spacing *
47. Spacer, countershaft (later design, replaces #'s 44-46) *
48. Gear, countershaft, third
49. Shaft, counter
50. Bearing, ball roller, countershaft rear *
51. Ring, retaining, countershaft rear bearing to case
52. Ring, retaining, countershaft rear bearing to shaft *
53. Gear, reverse idler, includes bushing
54. Shaft, reverse idler
55. Cover, PTO port
56. Gasket, PTO port cover *
57. Screw, countershaft front bearing cover plate
58. Plate, countershaft front bearing cover
59. Gasket, countershaft front bearing cover *
60. Plug, drain
61. Plug, filler
62. Gasket, top cover *
63. Gasket, rear tailhousing to case *
64. Bolt, PTO cover plate
65. Seal, oil, 2wd style *
Key items of interest:
Kit PTO-K, PTO cover, six bolt style, billet Part #: K-PTO Weight: 1.01 Price: $41.00 Buy:
Adapter, casting, SM465 transmission to NP208 & NP241 transfer cases, improved OEM reproduction, 356 alloy, hardened to T6 Part #: 15598986 Weight: 14.22 Price: $174.72 Buy:
Kit, shifter retention, SM420, SM465, NP435, T176 Part #: SLR-176K Weight: 0.32 Price: $17.20 Buy: Includes retention spring, domed washer, retainer and rubber boot
Kit 465CSC, cover, front, countershaft, SM465 transmission Part #: 465CSC Weight: 0.15 Price: $39.00 Buy:
Stick, shifter cane, SM420 & SM465 transmissions, upgraded one-piece version Part #: WT304-28 Weight: 2.58 Price: $68.25 Buy:
La franja horaria es GMT -3. Ahora son las 02:48:40.
