General Temas no técnicos, Saludos y Sugerencias referentes a 4x4 y Offroad. |
10-01-2008, 16:42:36 | #1 |
Ford BroncoII 89
Hola, quien sabe los diferenciales de una ford BroncoII del año 89, entiendo que ese año la mejoraron y de 2.8 paso 2.9cc..Horsepower 140 a 4600rpm...Torque 170 a 2600rpm...
Saludos,.... |
10-01-2008, 18:34:21 | #2 |
Re: Ford BroncoII 89
145hp, dana 30 o 28 delantero y trasero Ford 7.5
10-01-2008, 19:26:10 | #3 |
10-01-2008, 20:01:35 | #4 |
Mejor para completar la información:
a) Cajas: '88-92 Rangers(4x4)/Bronco2(4x4 & 2wd) motor 2.9 engine pueden ser: 1)Mitsubishi FM146 (2.9 4x4 SOLAMENTE) 2)Mazda M5OD-R1 (4x4 version) b) Transfer: Debería ser una Borg Warner 1350 (Mec o Elec): c) Diferenciales: TRASERO: Ford 7.5-Inch Application: Rear Type: Semi-floating Axle Shaft Diameter: 1.2 Inches Spline count: 28 Ring Gear Diameter: 7.5 Inch Maximum tire size for stock axle: 33-inch Strong point: Approximately the same pinion diameter as a Dana 60, mass availability. Weak point: C-clips. DELANTERO: Dana 28 TTB Applications: Front Axle Shaft Diameter: 1.0 Inches Spline count: 23 Ring Gear Diameter: 6.625 Inch Maximum tire size for stock axle: 31-inch Strong Points: Light weight making it good for mud. Can easily be made to produce very good articulation with only the addition of longer radius arms and custom coils. Weak Points: Outer axle shafts break. Radius arm bushings- especially passenger side frequently need replacing due to being too close to the catalytic converters. Brakes have a tendency to warp and/or crack the front rotors. Steering the stock steering set-up is very poor for a lifted truck. Severe bump steer is usually the result, in the higher lifts (4" and up) d) Motor: Engine Family Cologne Engine Displacement (Cubic Inches) 177 Cylinders 6 Arrangement of Cylinders "V" Shape Bore x Stroke 3.66 x 2.83 Compression Ratio 9.0:1 Valvetrain Pushrod Overhead Valve Fuel System MPFI (Multiport Electronic Fuel Injection) Fuel Pressure 30-40psi Horsepower 140hp @ 4600rpm Torque 170hp @ 2600rpm Oil Pressure 20psi @ warm Idle 55psi @ 2000rpm Espero haber sido de ayuda, Saludos, Pato |
11-01-2008, 08:01:39 | #5 |
Gracias Pato, quiero revisar si es una buena base como para empesar a a tranformar con unos 33x12,5x15 y un levante de 3" para empezar.....
11-01-2008, 08:14:03 | #6 | |
Applications: Front Axle Shaft Diameter: 1.0 Inches Spline count: 23 Ring Gear Diameter: 6.625 Inch Maximum tire size for stock axle: 31-inch El diferencial delantero es casi = al del samurai....33 vas a romper.- |
11-01-2008, 10:08:30 | #7 |
Hola y gracias, que me recomiendan por cual cambiar....cuanto mas menos otro diferencial $$$$
Compartir en Redes Sociales |
