| R/C Off Road Foro exclusivo para autos radiocontrolados Off Road, Stadium Truck, RC Crawling, etc. |
Herramientas |
#1 |
Eso amigos aprovecho de dar el dato por que según yo están baratas. pero aparte del enchufe no se que diferencia tienen.
http://www.mirax.cl/detalles.php?codigo=138193 http://www.mirax.cl/detalles.php?codigo=138194 saludos |
#2 | |
saludos desde Quilpue |
#3 |
Yo tambien me hice la misma pregunta la semana pasada.
Alguien con mas experiencia, de los antigüos, podria ver si realmente existe alguna diferencia importante o simplemente es el valor y el enchufe???? Saludos. Rodrigo Calquín Toro. |
#4 |
Aqui estan los specs de las 2 ..
DURATRAX DTXC 2063 BATERIA NIMH 7.2V ONYX 5000MA This is the DuraTrax NiMH 7.2V 5000mAh Onyx Stick Battery Pack with Standard Connector. FEATURES: Ideal sport pack for cars, trucks and boats INCLUDES: DuraTrax NiMH 7.2V 5000mAh Onyx Stick Battery with Standard Connector REQUIRES: NiMH compatible charger such as the Duratrax Onyx series SPECS: Capacity: 5000mAh Number of Cells in Series: 6 Rated Voltage: 7.2V Min. Discharge Voltage: 5.4V Maximum Recommended Charge Current: 5 amps Discharge Lead: 14AWG 2.7" (70mm) long wire w/Standard connector Pack Dimensions: 5.3 x 1.8 x 0.94" (135 x 45 x 24mm) Weight: 15.6 oz (442 g) Number of Welds per Connection: 6 spot welds Cell Size: Sub-C DURATRAX DTXC 2151 BATERIA NIMH 7.2V DTX 5000 ST This is the DuraTrax 6 cell 7.2V 5000mAh NiMH Flat Battery Pack with Dean's Ultra Connector. FEATURES: Ideal pack for weekend car, buggy, truck and boat racers as well as the serious competition racer who wants a less expensive alternative to matched packs for race preparation and practice, and who prefers Deans Ultra plugs Dean's Ultra female battery connector pre-installed on 12 gauge wire Soldered Silver battery bars INCLUDES: One DuraTrax 6 cell 7.2V 5000mAh NiMH Flat Battery Pack REQUIRES: Charger capable of charging NiMH batteries, such as the DuraTrax Onyx series or the Great Planes TRITON series SPECS: Capacity: 5000mAh Number of Cells in Series: 6 Rated Voltage: 7.2V Min. Discharge Voltage: 5.4V Maximum Recommended Charge Current: 4A Discharge Lead: 12AWG 3.1" (80mm) long wire with Deans Ultra Female Connector Dimensions: 5.5 x 1.9 x 1.0" (140 x 48 x 25mm) Weight: 462g (16.3oz) Cell Connection: Soldered Silver Battery Bars Cell Size: Sub-C Saludos !!! |
#5 |
Entonces, cual conviene mas???
#6 |
Por precio la mas barata .. yo no veo una gran diferencia .. a pesar de que dicen que hay baterias de primera seleccion y de segunda seleccion !!!
Hay que tomar en cuenta que no las utilizamos en rangos de sacarles el jugo como en competencias .. Saludos !!! |
#7 | |
Ta claro entonces, vamos por la mas barateli. Saludos y gracias. Rodrigo Calquín Toro. |
#8 |
#9 |
La DTX es mejor que la onyx, es considerada como pack sport, yo tengo de las 2 y la DTX entrega mas o en mejor forma los amperes, según mi experiencia usandolas en rally.
Saludos! |
#10 |
Edad: 77
