Antiguo 20-11-2010, 19:29:07   #1
Alvaro Sandoval
Predeterminado warn 8274 cuanto aceite ??????
eso alguien tiene informacion de la capacidad de aceite para un warn 8274 y que tipo ,unos dicen ATF otros W30 ,
Alvaro Sandoval está offline   Responder Con Cita
Antiguo 20-11-2010, 23:04:40   #2
Predeterminado Re: warn 8274 cuanto aceite ??????
SAE 30 no detergente. Cantidad debe ser alrededor de 2 litros, no lo tengo muy claro pero se que en la web eh visto el manual.
Antiguo 21-11-2010, 04:56:31   #3
Alvaro Sandoval
WARN M8274-50 PN 38631 - 12V PN 375832 - 24V
FASTEST LINE SPEED, LONGEST WIRE ROPE, LEGENDARY PERFORMANCE
Loved by off-roaders who compete, it's our fastest winch. No load retrieval speed for the M8274-50 is 73.4 feet per minute, and that's not all. At 150 ft. of 5/16" cable, it also has a very long line capacity. Its unique spur-gear drive train and upright design are totally rugged. Its braking system delivers smooth operation with superior heat dissipation. Roller fairlead, remote control on 12-ft. lead, free spool clutch and battery cables are included.
M8274-50 SPECS/PART NUMBERS Rated Line Pull: 8,000 lbs. (3630 kgs) single-line Intended Use/Application: Vehicle Recovery / For Trucks and SUVs Motor: 12V 4.6 hp/3.43kw, 24V 2.5 hp/3.43kw, Series Wound Duty Cycle Rating: Remote Control: Remote, 12' (3.7m) lead Geartrain: Spur Gear Gear Ratio: 134:1 Lubrication: 6 oz. SAE 30 (non-detergent) Clutch (freespooling): Sliding Motor Pinion Gear Brake: Automatic, disc type Drum Diameter/Length: 3.5"/8.5" (9cm/22cm) Weight: 110 lbs. (50 kgs.) Wire Rope: 150', 5/16" diameter (46m, 8mm diam.) Fairlead: Roller Recommended Battery: 650 CCA for winching Battery Leads: 2 gauge, 72" (1.83m) Finish: Argent Gray Powder Coat with Clear Coat Nuts: PN 7616, L/W: PN 2146 Bolts: PN 7165 CE Winches: CE products are designed to meet European Standards. CE winches include CE labels, manuals, roller fairlead, safety hook and thimble.
12V DC PERFORMANC
encontre esto en la web dice 6oz , no sera muy poco son como 0.15 lts o estoy mal en la conversion ?
Última edición por Alvaro Sandoval fecha: 21-11-2010 a las 08:00:26
Antiguo 21-11-2010, 09:30:07   #4
SVarasV
Jeepmaniac
Avatar de SVarasV
Son 177cc para ser exactos.
La franja horaria es GMT -3. Ahora son las 09:19:08.
