Antiguo 24-08-2010, 20:39:37   #1
Personalized
Icon Rifles2 Relojes autometer en stock
Amigos,
tambien tengo en stock relojes AUTOMETR:
  • 23023-3/4" TACH, 8,000 RPM, SHIFT-LITE, BLACK $101,947
  • 23003-3/4" TACH, 8,000 RPM, BLACK $ 59,720
  • 2339045" TACH, 10,000 RPM, SHIFT-LITE, AUTO GAGE $118,927
  • 2339055" TACH, 8,000 RPM, SHIFT-LITE, AUTO GAGE $118,927
  • 2339115" TACH, 10,000 RPM, SHIFT-LITE, AUTO GAGE $129,336
  • 62903-3/4" TACH, 10,000 RPM, SHIFT-LITE, COBALT $179,607
  • 59903-3/4" TACH, 10,000 RPM, SHIFT-LITE, ES $179,607
  • 4303-M2" BOOST-VAC, 60 Cm HG- 2.0 BARS, MECH $51,900
  • 43762" BOOST-VAC, 30 IN. HG/ 15 PSI, FSE, ULTRA-LITE $169,946
  • 43632" FUEL PRESS, 0-100 PSI FSE, W/O PEAK & VALLEY $191,634
  • 4327-M2" OIL PRESS, 0-7 BARS, SSE, ULTRA-LITE $58,281
  • 4337-M2" WATER TEMP, 40-120`C, SSE, ULTRA-LITE $44,146
  • 4348-M2" OIL TEMP, 60-170`C, SSE, ULTRA-LITE $44,748
  • 43272" OIL PRESS, 0-100 PSI, SSE, ULTRA-LITE $58,839
  • 43532" OIL PRESS, 0-100 PSI, FSE $184,683
  • 43562-1/16" OIL TEMP, 100- 340`F, FSE $133,319
  • 5927-M2-1/16" OIL PRESS, 0-7 BARS, SSE, ES $66,437
  • 5937-M2-1/16" WATER TEMP, 40- 120`C, SSE, ES $52,480
  • 5948-M2-1/16" OIL TEMP, 60- 170`C, SSE, ES $53,049
  • 6148-M2-1/16" OIL TEMP, 60- 170`C, SSE, COBALT $53,049
  • 6103-M2-1/16" BOOST-VAC, 60 CM/HG-2.0 BARS, MECH $58,705
  • 5903-M2-1/16" BOOST-VAC, 60 CM/HG-2.0 BARS, MECH, ES $58,705
  • 5737-M2" WATER TEMP, 40-120`C, SSE, PHANTOM $43,555
  • 5727-M2" OIL PRESS, 0-7 BARS, SSE, PHANTOM $57,969
  • 5703-M2" BOOST-VAC, 60 Cm HG- 2.0 BARS, MECH, PHANTOM $52,279
  • 57912" VOLTMETER, 8-18 VOLTS SSE, PHANTOM $38,200
  • 6127-M2-1/16" OIL PRESS, 0-7 BARS, SSE, COBALT $66,437
  • 6137-M2-1/16" WATER TEMP, 40- 120`C, SSE, COBALT $52,480
  • 22042" MOUNTING CUP, BLACK, PLASTIC GAUGE $ 4,436
  • 32246' COPPER TUBING, 1/8" DIA. $9,059
  • 3327-M2" OIL PRESS, 0-7 BARS, SSE, SPORT-COMP $56,351
  • 33912" VOLTMETER, 8-18 VOLTS SSE, SPORT-COMP $36,560
  • 3304-J2" BOOST-VAC, 2.5 Kg/Cm2 MECH $47,604
  • 3311-J2" FUEL PRESS, 0-1.0 Kg/ Cm2 $44,760
  • 3337-M2" WATER TEMP, 40-120`C, SSE, SPORT-COMP $42,584
  • 3341-M2" OIL TEMP, 60-140`C, MECH $65,310
  • 3348-M2" OIL TEMP, 60-170`C, SSE, SPORT-COMP $42,584
  • 3332-M2" WATER TEMP, 50-115`C, MECH $65,310
  • 3303-M2" BOOST-VAC, 60 Cm HG- 2.0 BARS, MECH $48,966
Personalized está offline   Responder Con Cita
Antiguo 02-09-2010, 13:50:46   #2
AndR3Z
Predeterminado Re: Relojes autometer en stock
Velocimetro no has traido?
Antiguo 26-09-2010, 02:25:38   #3
Jorge Guerra
tienes:
pirometro SPORT-COMP Mod: 3343
Indicador aire/full digital Phantom Mod: 5775 ambos autometer?
Jorge Guerra está offline   Responder Con Cita
Antiguo 29-09-2010, 22:15:33   #4
Fronti4x4
Avatar de Fronti4x4
Hola, ¿que tipo de conexión traen los relojes de boost? ¿se podrán instalar en una nissan terrano 2.5 tdi?
Fronti4x4 está offline   Responder Con Cita
Antiguo 26-10-2010, 08:55:47   #5
andres785
Me puedes mandar una foto del 23003-3/4" tach, 8,000 rpm, black $ 59,720 al correo andres@automovilesdecar.cl
gracias
La franja horaria es GMT -3. Ahora son las 09:06:45.
