#1 |
he tenido varias veces la información,,,pero ahora está perdida..jaajja
alguien tendrá los apretes del motor cherokee 4.0..??? gracias jav |
#2 |
Esta es la forma correcta de darle el torque a la Culata, "casi" nadie lo hace así
CAUTION: During the final tightening sequence, bolt No.11 will be tightened to a lower torque than the rest of the bolts. DO NOT overtighten bolt No.11. (a) Tighten all bolts in sequence (1 through 14) to 30 N·m (22 ft. lbs.) torque. (b) Tighten all bolts in sequence (1 through 14) to 61 N·m (45 ft. lbs.) torque. (c) Check all bolts to verify they are set to 61 N·m (45 ft. lbs.) torque. (d) Tighten bolts in sequence: ² Bolts 1 through 10 to 149 N·m (110 ft. lbs.) torque. ² Bolt 11 to 135 N·m (100 ft. lbs.) torque. ² Bolts 12 through 14 to 149 N·m (110 ft. lbs.) torque. (e) Check all bolts in sequence to verify the correct torque. (f) If not already done, clean and mark each bolt with a dab of paint after tightening. Should you encounter bolts which were painted in an earlier service operation, replace them. <-- Front of engine, bolt numbers torque sequence. 12-8-4-1-5-9-13 11-7-3-2-6-10-14 Yo la torqueo, no problem salu2, Pato |
#3 |
Va toda la data ...
Jeep 1999 4.0L Engine Torque Specifications Description Torque A/C Compressor Bracket to Engine Bolts 34 N· m 25 ft. lbs. A/C Compressor Mounting Bolts 27 N· m 20 ft. lbs. A/C Low Pressure Service Valve Nut 38 N· m 28 ft. lbs. Block Heater Nut 2 N· m 16 in. lbs. Camshaft Sprocket Bolt 68 N· m 50 ft. lbs. Camshaft Thrust Plate to Cylinder Block Screws 24 N· m 18 ft. lbs. Clutch Cover to Flywheel Bolts 54 N· m 40 ft. lbs. Coil Bracket to Block Bolts 22 N· m 192 in. lbs. Connecting Rod Nuts 45 N· m 33 ft. lbs. Cylinder Block Drain Plugs 34 N· m 25 ft. lbs. Cylinder Head Bolts 135 N· m 100 ft. lbs. Cylinder Head Cover Bolts 10 N· m 85 in. lbs. Distributer Clamp Bolt 23 N· m 204 in. lbs. Engine Mounts - Front Support Bracket Bolts 61 N· m 45 ft. lbs. Engine Mounts - Front Support Cushion Bolts/Nuts 41 N· m 30 ft. lbs. Engine Mounts - Front Support Cushion Bracket Bolts 54 N· m 40 ft. lbs. Engine Mounts - Front Support Cushion Bracket Stud Nuts 41 N· m 30 ft. lbs. Engine Mounts - Front Support Cushion Thru-Bolt 65 N· m 48 ft. lbs. Engine Mounts - Rear Crossmember-to-Sill Bolts (Automatic) 41 N· m 30 ft. lbs. Engine Mounts - Rear Insulator Stud Assembly Nut 41 N· m 30 ft. lbs. Engine Mounts - Rear Support Cushion/Crossmember Nuts 22 N· m 192 in. lbs. Engine Mounts - Rear Support Cushion/Bracket Nuts (Manual) 75 N· m 55 ft. lbs. Transmission Support Bracket Bolt (Manual) 46 N· m 34 ft. lbs. Transmission Support Bracket/Cushion Bolt (4WD Auto) 75 N· m 55 ft. lbs. Transmission Support Adapter Bracket Bolts (2WD Auto) 75 N· m 55 ft. lbs. Exhaust Manifold/Pipe Nuts 27 N· m 20 ft. lbs. Flywheel to Converter Housing Bolts 38 N· m 28 ft. lbs. Flywheel to Crankshaft Bolts 143 N· m 105 ft. lbs. Front Cover-to-Block Bolts ¼-20 7 N· m 60 in. lbs. Front Cover-to-Block Bolts 5/16-18 22 N· m 192 in. lbs. Fuel Rail Bolts/Stud 12 N· m 108 in. lbs. Generator Fixed Bolt 24 N· m 18 ft. lbs. Generator Thru Bolt/Nut 38 N· m 28 ft. lbs. Main Bearing Cap Bolts 108 N· m 80 ft. lbs. Main Bearing Brace Nuts 47 N· m 35 ft. lbs. Oil Filter 18 N· m 156 in. lbs. Oil Filter Connector (to adapter) 47 N· m 35 ft. lbs. Oil Filter Connector (to block) 68 N· m 50 ft. lbs. Oil Filter Adapter Bolts 102 N· m 75 ft lbs Oil Galley Plug 41 N· m 30 ft. lbs. Oil Pan ¼-20 Bolts 9.5 N· m 84 in. lbs. Oil Pan 5/16-18 Bolts 15 N· m 132 in. lbs. Oil Pan Drain Plug 34 N· m 25 ft. lbs. Oil Pump Short Attaching Bolts 23 N· m 204 in. lbs. Oil Pump Long Attaching Bolts 23 N· m 204 in. lbs. Oil Pump Cover Bolts 8 N· m 70 in. lbs. Power Steering Pump Pressure Hose Nut 52 N· m 38 ft. lbs. Rocker Arm Assembly-to-Cylinder Head Capscrews 30 N· m 21 ft. lbs. Spark Plugs 37 N· m 27 ft. lbs. Starter Motor Mounting Bolts 45 N· m 33 ft. lbs. Thermostat Housing Bolts 18 N· m 156 in. lbs. Throttle Body Bolts 10 N· m 90 in. lbs. Vibration Damper Bolts 108 N· m 80 ft. lbs. Water Pump/Block Bolts 23 N· m 17 ft. lbs. |
#4 |
Será todo una gran mejora, va ahora con unos Upgrades nuevos y lo más importante, ahora quedará como reloj siuzo, muy suave y perfectamente sintonizado
Una Gran creación esta por nacer Salu2, Pato Última edición por Pato-Patrol fecha: 05-05-2010 a las 20:08:21 |
