Antiguo 08-04-2009, 18:44:42   #1
Eduardo Silva
Avatar de Eduardo Silva
Predeterminado Jeep Grand Cherokee 2011
Fuente: Autospies.com
Mas FOTOS
New Quadra Lift™ air suspension system provides height control and lifts vehicle up to 4.5 inches from park mode to a maximum ride height of 11.1 inches to deliver legendary Jeep off-road capability
Choice of three 4x4 systems – Quadra-Trac I®, Quadra-Trac II® and Quadra-Drive® II with Electronic Limited-Slip Differential (ELSD)
• New Selec-Terrain™ system with Quadra-Trac II and Quadra-Drive II offers five terrain settings: Auto, Sand/Mud, Sport, Snow and Rock to match driving conditions
• First application of company's all-new, flexible fuel 3.6-liter V-6 engine which features Variable-Valve Timing (VVT), 280 hp (209 kW) and 260 lb.-ft. of torque (353 N•m) @ 4,800 rpm – an increase of 33 percent in horsepower, 11 percent in torque over its predecessor and up to an 11 percent improvement in fuel economy.
• Available 5.7-liter HEMI® V-8 generates 360 hp (268 kW) and 390 lb.-ft. of torque (520 N•m) @ 4,250 rpm – features VVT and fuel-saving Multi-displacement System (MDS) technology with dual exhaust to maximize efficiency
• For international markets, left- and right-hand drive and a choice of diesel and petrol powertrains will be available
• Unsurpassed trailer tow capability of up to 7,400 lbs. on 4x2 models
• Larger fuel tank with 24.6 gallon capacity, compared to 21.6 on current model, combined with improved V-6 fuel economy, delivers range close to 500 miles on one tank of gas
Antiguo 08-04-2009, 18:49:48   #2
Eduardo Silva
Predeterminado Re: Jeep Grand Cherokee 2011
Otro reportaje y mas fotos en Jalopnik.com
Antiguo 08-04-2009, 18:51:05   #3
Eduardo Silva
Está construido sobre la misma plataforma que el Mercedes ML:
"The next-generation Jeep Grand Cherokee's built on the same rear-wheel-drive unibody platform underpinning the new Mercedes-Benz ML"
Antiguo 08-04-2009, 18:56:32   #4
Outland
ayer vi pasar por keneddy un amg 63ml y andaba como moto quede padentro , este no sera mucho menos creo yo no ?
Outland está offline   Responder Con Cita
Antiguo 08-04-2009, 18:57:05   #5
mlucero
Avatar de mlucero
Edad: 37
Contactar con mlucero a través de MSN
no me gusto para nada... como que le encontre cierto parecido al tribeca
mlucero está offline   Responder Con Cita
Antiguo 08-04-2009, 19:02:33   #6
Eduardo Silva
Empezado por mlucero Ver Mensaje
Ese es el punto! el propósito de este diseño es que los que ahora compran un Tribeca se cambien a Jeep
Antiguo 08-04-2009, 19:32:33   #7
Seguro?
Porque ya no existe mas DaimlerChrysler y no creo que la plataforma del nuevo GCH sea del ML
Antiguo 08-04-2009, 19:44:01   #8
Eduardo Silva
Seguro?
Eso dice el artículo, y tiene bastante sentido...
"The next-generation Jeep Grand Cherokee's built on the same rear-wheel-drive unibody platform underpinning the new Mercedes-Benz ML. It's one of the few things Chrysler got out of its ill-fated "merger of equals" with the German automaker. There's also a new Quadra Lift air suspension system that provides height control and lifts the new Grand Cherokee up 4.5" from park mode to a maximum ride height of 11.1" for better off-road capability. There's also a select-trac system with four separate 4x4 systems, each set up for different driver needs. But of all that, the chassis's about the only thing they get from Mercedes. It's at this point in a preview piece on a Chrysler vehicle where we'd attack the rest of the vehicle for being a complete waste of time. It's not. The exterior body of the new Grand Cherokee gets an all-new sculpted body that helps give the new Grand Cherokee an athletic profile despite the increase in size and weight. It looks good in photos. In person it looks, and most importantly, feels, fantastic."
Antiguo 08-04-2009, 20:02:19   #9
wrangler_sahara
bien feo el jeep
si ese es el nuevo que pena por jeep que los modelos pasen a ser autos con la tipica forma que ocupan las mujeres
wrangler_sahara está offline   Responder Con Cita
Antiguo 08-04-2009, 21:03:35   #10
Roland
Avatar de Roland
Parece un auto mas grande
La franja horaria es GMT -3. Ahora son las 08:44:57.
