Antiguo 07-12-2007, 11:34:51   #1
zp 4.0
Predeterminado Neumaticos TrXsus M/T,
Vendo 4 neumaticos interco TrXsus M/T con 4.000 km recorridos.
33-12,50-15 $350.000.-
Jaime Valderrama
092356186
Review of the Interco TrXus® Mud Terrain
The TrXus Mud Terrain tire is Interco Tire Corporations Mud terrain tire that competes directly with other popular Mud terrain tires like the BFGoodrich MT T/A KM which attempt to give the consumer a mud terrain performance while behaving well on the street. As with the other Interco tires, the TrXus excels in their design. First the TrXus uses the three stage lug design which has proved itself impressively in not only mud but also on the rocks, in deep snow, on loose grainy terrain and on the changing wooded trails. Down the center of the TrXus are a variation on Intercos two center row design of alternating "v" shaped lugs, which incorporate sipes that allow the tire to grip not just on the rocks but better on wet roads and in icy conditions than typical mud terrain tires would. The center lugs as well as parts of the outer lugs incorporate a "stepped" design that allows better release of mud and debris for better self cleaning as the wheel rotates around through the terrain. Sidewalls are protected by a supplemental tread design that not only servers to reduce sidewall damage but also assists with finding grip. The TrXus is available in both Bias and Radial designs. The for users who are looking for a good Mud Terrain that also drive well on the road, the Radial design is the tire you will want where on road handling is better than you might expect. Sizes available up to 38" with plys ranging 6 and 8 on the Radials and 8 and 10 in the Bias Plys.
zp 4.0 está offline   Responder Con Cita
Antiguo 07-12-2007, 14:05:46   #2
alejo2112
Avatar de alejo2112
Predeterminado Re: Neumaticos TrXsus M/T,
ja ja...veo que Linares 3.0 te dejó "pidiendo más" ja..ja me pasó lo mismo en el Linares 1.0 que pasé de BFG a SWAMPER......que se viene?? BOGGER?
Suerte con la venta....esos neumaticos están NUEVOS!!!
Antiguo 11-12-2007, 10:58:50   #3
zp 4.0
Se vienen unos Irok 36.
Empezado por alejo2112 Ver Mensaje
Antiguo 11-12-2007, 11:07:19   #4
caxtrol
Hola
Son Bias o Radiales ????
Caxtrol
caxtrol está offline   Responder Con Cita
Antiguo 11-12-2007, 11:58:35   #5
Zorro
Empezado por zp 4.0 Ver Mensaje
Caliente...
Antiguo 11-12-2007, 15:14:00   #6
zp 4.0
Radiales
Empezado por caxtrol Ver Mensaje
Hola
Caxtrol
Antiguo 11-12-2007, 16:49:47   #7
caxtrol
Hola
Aceptas oferta y facilidades de pago.
Caxtrol
Antiguo 11-12-2007, 17:45:40   #8
zp 4.0
Post Re: Neumaticos TrXsus M/T,
algo.....
Caliente...
Antiguo 11-12-2007, 17:46:11   #9
zp 4.0
Ofertas al contado.
slds.
Hola
Caxtrol
Antiguo 11-12-2007, 17:47:35   #10
V A M P I R O
Tocayo, hable con el Alejo, derrepente se pueden conseguir un buen precio comprando dos juegos de irocks
La franja horaria es GMT -3. Ahora son las 02:34:59.
