Antiguo 27-12-2006, 07:07:31   #1
V A M P I R O
Predeterminado Ebay Land Cruiser
http://cgi.ebay.com/ebaymotors/Toyot...ayphotohosting
You are Bidding on a Custom Built 1964 LandCruiser. This LandCruiser has the following Features: Full tube chassis, four wheel steering(Howe Rams, Howe Pump, Howe Filter/Reservoir,Electric Rear Pump,), 388 C.I. Small Block Chevy (560 HR) all new. 060" over 350/400 Steel Crank, 5.7" Rods H. Beam, 67cc Edelbrock #6089 Heads ported 2.02/1.60 Valves, kick out pan with diamond tray & crank scraper, block shaved for poralasis/oil drains blocked over crank, full balanced rotating assembly, 100 C.F.M fuel injection Edelbrock Pro Flo,Aeroquip Pump & fuel regulation, turo 400 auto, 3000-3500 TCI Stall converter/furnace brazed hub, reverse pattern valve body (manual shift), Art Car internals, Art Car reverse pattern shifter, Atlas 4.3-1 transfer case/32 spline output shafts, seperate coolers & fan for oil, transmission, power steering, all plumbing is high quality A-N fittings & hoses, ultra clean wire installation with fused protection, 600 watt sound system with six disc changer (Alpine/soundstream), all Aluminum floor boards/firewalls/dash/stereo console, all Aluminum tilt streeing column, Aluminum radiator, Aluminum Grill, Warn 9500lbs high speed winch with kevlar rope, Series/parallel switch for high amperage 12-24 VDC, Welding port @24 VDC, 24 VDC Oasis Compressor, 3 seats with 5 point harnesses, full set Autometer gauges include: speedometer; R.P.M; oil pressure; oil temperature; transmission temperature; pyrometer; water temperature; volt meter, dual alternators(130 AMP units), Fresh air intake (stainless), 3" dual exhaust (stainless), 1 7/8" Sanders headers, 3 quart oil accumulator with gauge & solenoid, 30 gallon aluminum fuel tank, shortened Rockwells with Detroits, 4 wheel disc brakes, Wilwood calipers & master/pedal, 16" x 2 sway away race runner coil overs, 4 link suspension front & rear, removable nylon skid plates on under belly, 44" x 18.5" x 15" TSL Swampers, steel double beed lock wheels, Matching Spare wheel, vinyl removable sun top, dual Optima batteries, full width ice chest rack, .065 thick 3" drive shafts 1350/1410 u-joints, with much much more!
Antiguo 27-12-2006, 13:10:10   #2
DESERTICO
Avatar de DESERTICO
Predeterminado La Raja
Estla la raja para ir al supermercado
Antiguo 27-12-2006, 13:30:04   #3
OB1
Avatar de OB1
Edad: 67
No me gusta, los dos alternadores le hacen perder mucha potencia :grin:
Realmente no se me ocurre qué más podría alguien querer hacerle
OB1
Antiguo 27-12-2006, 15:36:16   #4
Ignacio
Avatar de Ignacio
Contactar con Ignacio a través de MSN
Empezado por OB1
OB1
Yo si ..... ponerle el autoadhesivo.....:
Ignacio está offline   Responder Con Cita
Antiguo 29-12-2006, 10:10:56   #5
Empezado por Ignacio
Por 45 k USD .. :D
Hay cosas en la vida que no tienen precio ..
Antiguo 29-12-2006, 11:07:55   #6
Roland
Avatar de Roland
Empezado por Tapage
Por 45 k USD .. :D
Para el resto use Master.....
La franja horaria es GMT -3. Ahora son las 20:46:41.
