Antiguo 22-06-2017, 16:52:32   #1
awarenica
Edad: 74
Predeterminado Amortiguadores Tough Dog
Buenas tardes
Deseo adquirir un juego de Amortiguadores Tough Dog Adjustable 40mm
Son interesantes porque son regulables
The 40mm adjustable shock brings the ability to fine tune your ride control to just about every 4WD user. The shock offers 9 different stages of adjustment, to fine tune the ride characteristics to your personal preference and application.
In reality, very few vehicles serve only one purpose. Most 4WD’s today are the family car, off road toy, touring escape, towing rig or tradesman’s work platform all rolled into one. We demand so much of our vehicles, and every situation will need something just a little bit different. As well as being fully adjustable, these shocks are equipped with our Foam Cell technology, minimising aeration and cavitation to maximise the shocks ability to resist fade, and perform reliably in harsh and demanding conditions. Our adjustable shocks are built tough for the Aussie outback, and incorporate an ABS plastic dust shield as well as an external dust wiper seal to protect the shock’s internals from grit which can damage the oil seals around the chrome rod. When fully extended, the shock is at its most vulnerable to damage from side load. The internal bump stop and piston rod guide ensure the shock is supported at the extremes of its travel. These tough units are available for a wide range of applications.
• 40mm internal bore
• 60mm external casing
• 18mm chrome-plated rod
• High temperature, all weather oil
• Foam cell
• 9 Stage external adjustment
• Additional welding on all studs and eye rings
• 2 year / 40,000km warranty (conditions apply)
Quien los comercializa?
Por favor si me pueden enviar datos de contacto.
Gracias
Alejandro Warenica
awarenica está offline   Responder Con Cita
Antiguo 06-07-2017, 17:02:21   #2
P"aTv"
Avatar de P"aTv"
Contactar con P"aTv" a través de MSN
Predeterminado Re: Amortiguadores Tough Dog
Empezado por awarenica Ver Mensaje
Buenas tardes
• Foam cell
Gracias
Alejandro Warenica
hola, no se quien los comercializa pero los rancho 9000XL tienen el mismo sistema de regulacion (9 posiciones) y esos si los encuentras en chile.
P"aTv" está offline   Responder Con Cita
Antiguo 08-07-2017, 12:27:10   #3
awarenica
Edad: 74
Gracias P"aTv"
Alejandro
La franja horaria es GMT -3. Ahora son las 23:40:46.
