Antiguo 27-03-2015, 17:45:22   #1
Toyota V8
Predeterminado consulta JK Rubicon
Alguien sabe como se le borra al wrangler jk,el aviso de cambio de aceite de motor en el tablero.
Gracias
Toyota V8 está offline   Responder Con Cita
Antiguo 28-03-2015, 18:54:26   #2
samir.18
Predeterminado Re: consulta JK Rubicon
Empezado por Toyota V8 Ver Mensaje
Gracias
No conozco ese jeep, de echo nunca lo he manejado, y creo que nunca me he subido a uno tampoco...
Pero "debería" desactivarse utilizando algún botón que este en el tablero o en el telecomando, como cuando se configura una radio.
Última edición por samir.18 fecha: 29-03-2015 a las 22:53:23
Antiguo 28-03-2015, 19:02:07   #3
samir.18
Contacto, apretar acelerador 3 veces, apagar y prender.
Change Oil Message
Your vehicle is equipped with an engine oil change
indicator system. The “CHANgE OIL” message will flash
in the instrument cluster odometer for approximately
12 seconds after a single chime has sounded to indicate
the next scheduled oil change interval. The engine oil
change indicator system is duty-cycle based, which
means the engine oil change interval may fluctuate
dependent upon your personal driving style.
Unless reset, this message will continue to display each
time you turn the ignition switch to the ON/RUN
position. To turn off the message temporarily, press and
release the Trip Odometer button on the instrument
cluster. To reset the oil change indicator system (after
performing the scheduled maintenance), refer to the
following procedure:
1. Turn the ignition switch to the ON position (Do not
start the engine).
2. Fully depress the accelerator pedal slowly three
times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE:
If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary repeat this procedure.
Última edición por samir.18 fecha: 28-03-2015 a las 19:08:05
La franja horaria es GMT -3. Ahora son las 18:08:47.
