Venden - Partes y accesorios para 4X4 Espacio para avisos de venta (de caracter no comercial) de partes y accesorios para 4x4. Todo mensaje que no tenga que ver con el tema será eliminado sin previo aviso. |
Herramientas |
#1 |
vendo caja de cambios peugeot, era de un cherokee 4.0 $500.000
Última edición por Chico_Flores fecha: 22-03-2014 a las 12:19:24 |
#2 |
#3 |
#4 |
X2....es Peugeot.
#5 |
Si es AX15 es japonés Aisin Warner. A mi interesa harto y me poingo de acuerdo con jorge daza.
Podrías sacarle una foto a los números de serie para rectificarlo? ![]() Cerremos luego porfa. Javier |
#6 |
ok, gracias por la aclaración, en que parte lleva los números de serie?, algún mail donde enviar las fotos?, saludos
#7 |
Algunos comentarios para verificar si es o no:
Identification The 4wd version of the AX15 transmission case is 16-1/2" long. It features a cast aluminum case with a cast-aluminum mid-plate. The case is generously ribbed and features the shifter in the rear quarter of the assembly. In the vein of newer transmissions, the AX15 uses dowel pins for bellhousing alignment. The 4wd version of the Jeep AX15 has a 23 spline output shaft for connecting to the transfer case input shaft. This shaft protrudes about 1/2" past the rear face of the transmission. The AX15 was used with an internal slave/throwout assembly up through the 1993 model year. In 1994, a more conventional slave cylinder and cross-arm were used. The input shaft is a 10 spline x 1-1/8" and its stickout length is 7-1/2". 1988 to 1991 AX15 input shafts have a smaller (~19/32") pilot tip. 1992-1999 AX15's have a larger (~3/4") pilot tip. The AX15 looks similar to the AX5 and are they are occasionally confused in identification as well as interchange. Quedo a la espera, Javier |
#8 | |
![]() Cita:
Saludos |
#9 |
#10 | |
![]() Cita:
Javier |
Compartir en Redes Sociales |
