Retroceder   TwistedAndes > Off Topic > Videos
Videos Foro exclusivo para Videos
Antiguo 19-04-2009, 18:39:32   #1
alfredo4x4
Predeterminado Esto si que es 4x4! KAMAZ Dakar / Master Rally
Impresionante la potencia que tienen esos camiones?? alguien sabe datos reales de esos 4x4?? motencia, motor, etc...
http://rootcars.com/videos.php?vid=578&tabla=u
alfredo4x4 está offline   Responder Con Cita
Antiguo 20-04-2009, 15:44:40   #2
Loly Pop
Avatar de Loly Pop
Predeterminado Re: Esto si que es 4x4! KAMAZ Dakar / Master Rally
la cago la potencia de esa makina!! que motro tiene cuantos hp?
Loly Pop está offline   Responder Con Cita
Antiguo 20-04-2009, 16:06:53   #3
Nicolas Rey
Contactar con Nicolas Rey a través de MSN
Kamaz 4911
Fuel System
Fuel tank capacity, l 400+400
Engine
Model YMZ-7E846
Type Diesel, turbocharged
Nominal power, gross, kWt (hp)/ at crankshaft rotation, rpm 538 (730) / 2500
Maximum torque, net, Nm (kgcm) / at crankshaft rotation, rpm 2700 / 1300-1400
Arrangement and number of cylinders V-shape, 8
Displacement, l 17,24
Cylinder diametre and piston stroke, mm 140/140
Compression ratio 15,2
Weights and Load capacities
Curb vehicle weight, kg 7250
Gross vehicle weight, kg 12000
Electrics
Voltage, V 24
Storage batteries, V/Ah 2x12/190
Generator, V/wt 28/2000
Clutch
Type Friction, dry, one-plate
Drive Hydraulic with pneumatic booster
Gearbox
Model 16S-251
Type Mechanical, 16-speed
Control Mechanical, remote
Brakes
Drive Pneumatic
Drum diametre, mm 400
Brake linings width, mm 220
Wheels and Tyres
Wheel type Disc
Tyre type Pneumatic, pressure adjustment
Rim size 12.2-20,9 (310-533)
Tyre size 425/85 R21 (1260x425-533P)
Cab
Type Over the engine, 3-seat
General Data
Maximum speed, not less, km/h 165
Maximum gradient, not less, % 36
Outer turning radius, m 11,3
Note! Specifications of 12 000 kg gross weight truck
Transfer Case
Type STYER VG2000/300, mechanical, two-speed with blocked interaxable differential
Gear ratio of high gears (low) 3,55
Nicolas Rey está offline   Responder Con Cita
Antiguo 21-04-2009, 16:38:32   #4
Loly Pop
Avatar de Loly Pop
Empezado por Nicolas Rey Ver Mensaje
Kamaz 4911
Fuel System
Engine
Model YMZ-7E846
Electrics
Voltage, V 24
Clutch
Gearbox
Model 16S-251
Brakes
Drive Pneumatic
Wheels and Tyres
Wheel type Disc
Cab
General Data
Transfer Case
gracias por las especificaciones!!
La franja horaria es GMT -3. Ahora son las 01:26:50.
