Antiguo 25-07-2013, 12:04:48   #1
Monster4x4
Predeterminado Oferta super charger ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
SUPER CHARGER NUEVO $ 2.890.500 INSUPERABLE PRECIO............
Complete systems are 50-State smog legal per CARB EO # D-213-28.
2007-2011 5.3L Truck/SUV: 452 HP, 444 lb/ft Complete Systems
The complete supercharger system will boost your stock 5.3L truck/SUV to 452HP and 444 lb/ft torque with 8.5 PSI from the Lysholm 2300 supercharger at the factory redline. This is an increase of 137HP and 106 lb/ft torque over the GM factory ratings.
More Systems Under Development
Complete systems for 2012 truck/SUV and 2007 "Classic" trucks are under development.
Complete Systems: Included Components and Features
Lysholm 2300 twin-screw supercharger with 3.80" pulley, integrated bypass valve and actuator. The twin-screw design provides maximum low-end torque as well as far greater efficiency and horsepower gains compared to the traditional (as well as newer) roots type blowers.
Supercharger drive assembly includes idler, drive belt and all hardware.
Fuel management upgrade includes a hand-held programmer (controls ignition timing and fuel enrichment), extruded aluminum replacement fuel rails, high-flow fuel injectors and braided stainless steel fuel hoses.
Integrated dual-pass air/water charge cooler configuration features a closed loop water cooling system with a stand alone pump, tank and front mounted heat exchanger. The aluminum charge cooler core features 50% more surface area than competitive kits for maximum temperature reduction.
Cast Aluminum air inlet manifold mates to OEM throttle body.
High-flow bypass valve provides for increased compressor efficiency and temperature control.
Roto-molded air inlet ducting maintains factory appearance and joins the stock air box and MAF.
Complete bolt-on system includes all necessary belts, pulleys, fasteners and a reusable high-flow air filter.
3-Year/36,000-mile powertrain limited warranty optional(term is from vehicle original in-service date).
Suggested retail price is $6250.95.
Due to the fuel system design on this vehicle, special ECM reprogramming will be required when additional aftermarket parts are added, such as smaller supercharger drive pulleys, large diameter headers/exhaust etc.
Not Compatible with Flex-Fuel Trucks
These systems are not compatible with Flex-Fuel trucks.
Complete System Part Numbers and Pricing
Complete systems include a fuel management/calibration upgrade and will bolt onto stock vehicles without the need for additional parts.
Download Installation Manual (PDF, 33MB): 4LGL020-010 v5.0.
Atte
Monster4x4 está offline   Responder Con Cita
Antiguo 25-07-2013, 15:52:10   #2
Cristian Moraga
Predeterminado Re: Oferta super charger ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
Tienes fotos o el link del kit?
Antiguo 25-07-2013, 20:08:07   #3
Rugby98
Avatar de Rugby98
Contactar con Rugby98 a través de MSN
Es para motores chevy 5.3 v8? sirve para una suburban 2011?
Rugby98 está offline   Responder Con Cita
Antiguo 25-07-2013, 20:45:50   #4
Monster4x4
http://www.lysholm.us/gm_truck_systems.php
Aca esta el LINK
Atte
Hernan
Antiguo 25-07-2013, 20:47:57   #5
Monster4x4
Empezado por Rugby98 Ver Mensaje
Para estar mas seguro voy a llamar mañana y te confirmo
Atte
Hernan
Antiguo 01-08-2013, 16:26:54   #6
Monster4x4
Hola no me arriesgo , en la paguina de VORTEC no la ponen o sea NO SIRVE sorry...
Atte
Antiguo 01-08-2013, 16:29:11   #7
Monster4x4
Antiguo 30-09-2013, 11:57:13   #8
Monster4x4
Empezado por monster4x4 Ver Mensaje
super charger nuevo $ 2.890.500 insuperable precio............
Complete systems are 50-state smog legal per carb eo # d-213-28.
2007-2011 5.3l truck/suv: 452 hp, 444 lb/ft complete systems
the complete supercharger system will boost your stock 5.3l truck/suv to 452hp and 444 lb/ft torque with 8.5 psi from the lysholm 2300 supercharger at the factory redline. This is an increase of 137hp and 106 lb/ft torque over the gm factory ratings.
More systems under development
complete systems for 2012 truck/suv and 2007 "classic" trucks are under development.
Complete systems: Included components and features
lysholm 2300 twin-screw supercharger with 3.80" pulley, integrated bypass valve and actuator. The twin-screw design provides maximum low-end torque as well as far greater efficiency and horsepower gains compared to the traditional (as well as newer) roots type blowers.
Cast aluminum air inlet manifold mates to oem throttle body.
Roto-molded air inlet ducting maintains factory appearance and joins the stock air box and maf.
3-year/36,000-mile powertrain limited warranty optional(term is from vehicle original in-service date).
Due to the fuel system design on this vehicle, special ecm reprogramming will be required when additional aftermarket parts are added, such as smaller supercharger drive pulleys, large diameter headers/exhaust etc.
Not compatible with flex-fuel trucks
these systems are not compatible with flex-fuel trucks.
Complete system part numbers and pricing
complete systems include a fuel management/calibration upgrade and will bolt onto stock vehicles without the need for additional parts.
Download installation manual (pdf, 33mb): 4lgl020-010 v5.0.
Atte
interesados ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡
Antiguo 16-10-2013, 09:32:58   #9
Monster4x4
Vendido ¡¡¡¡
gracias
La franja horaria es GMT -3. Ahora son las 19:40:07.
