Antiguo 02-08-2007, 13:47:40   #11
-ArtSerey-
Predeterminado Re: Unimog Axle Tech
...un poco mas de 406 y 416
http://www.unimogcentre.com/unimog406.html
...cito:
As with other Unimogs the 406/416 use portal axles with reduction hubs. The standard final axle ratio is 6.5:1 although 6.0:1 and 5.3:1 are also available. With the standard gear ratios and 12.5R20 tires, the 406/416 has a top speed of about 52 mph (@2800 rpm) while with the high-speed axles and 14.5R20 tires speeds of 65+ mph (@2800) are achievable.
slds..
traktorke
Antiguo 02-08-2007, 16:36:19   #12
mmm, cual es el Baumuster??
403.120 U 54
403.121 U 54
403.122 U 66,U 72,U 800
403.123 U 66,U 72,U 800
404.113 U S 404
404.114 U S 404
404.115 U S 404
404.117 U S 404
405.100 U 300
405.102 U 400
405.120 U 300
405.122 U 400
405.200 U 500
405.210 UGN NA
405.220 U 500
405.230 UGN NA
406.120 U 65,U 70,U 80,U 84, U 900
406.121 U 65,U 70,U 80,U 84, U 900
406.130 U 65 T,U 70 T
406.131 U 65 T
406.133 U 80 T
406.142 U 900
406.143 U 900
407.100 U 600
407.110 U 650
407.111 U 650 L
407.200 U 600
407.210 U 650
407.211 U 650 L
408.100 U 90
408.101 U 90 TURBO
408.215 U 100 L
408.216 U 100 L TURBO
413.110 U 80,U 72,U 800 L
413.111 U 80,U 72,U 800 L
416.114 U 100,U 1100 L
416.115 U 100,U 1100 L
416.116 U 100,U 1100 L
416.117 U 100,U 1100 L
416.122 U 80,U 90
416.123 U 80,U 90
416.124 U 80,U 90
416.125 U 80,U 90
416.126 U 80,U 90
416.127 U 80,U 90
416.130 U 80 T,U 90T
416.133 U 80 T,U 90 T
416.134 U 100 T,U 110 T,U 1100 T
416.135 U 100 T,U 110 T,U 1100 T
416.140 U 100,U 110,U 1100
416.141 U 100,U 110,U 1100
416.160 U 100,U 1100 L
416.162 U 125,U 1100 L
416.163 U 125,U 1100 L
417.000 U 1100 T
417.100 U 800
417.101 U 900
417.106 U 900
417.110 U 1150
417.111 U 1150 L
417.115 U 1150
417.116 U 1150 L
417.120 U 1150 L/34
417.200 U 800
417.201 U 900
417.210 U 1150
417.211 U 1150 L
417.212 U 1150 L
417.220 U 1150 L/34
418.000 U 130 T U 140 T
418.100 U 110
418.102 U 130 U 140
418.115 U 110 L
418.117 U 140 L
418.217 U 140 L
418.237 U 140 L/39
421.122 U 40,U 45
421.123 U 40,U 45
421.124 U 52,U 600
421.125 U 52,U 600
421.128 U 60,U 600 L
421.129 U 60,U 600 L
421.130 U 40 T,U 55 T
421.131 U 40 T,U 55 T
421.132 U 60 T,U 600 T
421.133 U 60 T,U 600 T
421.140 U 52,U 600
421.141 U 52,U 600
421.162 U 60
421.163 U 60
424.121 U 1000
424.122 U 1200
424.126 U 1250,U 1550
424.127 U 1250 L,U 1550 L
424.131 U 1000 T
424.132 U 1200 T
425.121 U 1300
425.131 U 1500 T
425.141 U 1500
427.000 U 1200 T U 1400 T
427.100 U 1000
427.101 U 1200
427.102 U 1400
427.105 U 1600
427.107 U 1600
427.110 U 1250
427.111 U 1250 L U 1450 L
427.112 U 1450
427.115 U 1650
427.116 U 1650 L
427.117 U 1650
427.118 U 1650 L
435.110 U 1700
435.111 U 1700 L
435.113 U 1700 L
435.115 U 1300 L
435.117 U 1300 L
435.160 TM 170
435.161 TM 215
436.320 U 1300 L
436.321 U 1300 L
436.325 U 1300 L
436.326 U 1300 L
436.340 U 1700 L/38
436.341 U 1700 L/38
436.342 U 1700 L/38
436.343 U 1700 L/38
437.000 U 1700 T
437.002 U 1800 T U 2100 T
437.100 U 1700
437.102 U 1800
437.105 U 2100
437.110 U 1350 L
437.111 U 1550 L
437.112 U 1750
437.113 U 1750 L
437.114 U 1850
437.115 U 1850 L
437.116 U 1550 L
437.117 U 2150
437.118 U 2150 L
437.120 U 1550 L/37
437.123 U 1550 L/38
437.125 U 1550 L/37
437.130 U 1750/38
437.131 U 1750 L/38
437.133 U 1850 L/38
437.135 U 2150 /38
437.136 U 2150 L/38
437.141 U 1550 L/45
437.156 U 2450 L/6X6
437.170 U 2150 L KOBRA
437.171 U 2150 L BUSHRANGER
437.182 U 2400 TG
437.420 U3000/U4000(UHN I 3250) K-ACHSE
437.425 U3000/U4000(UHN I 3850) K-ACHSE
cual de todos esos es???
Antiguo 02-08-2007, 16:38:00   #13
Sobre el Dyna, hay eje rigido y una especie de IFS, el mismo que usa el Megacruiser y el Coaster (bus).
Ahora hay unos que son similares a la Hilux, pero solo se venden en Japon.
Antiguo 02-08-2007, 18:32:04   #14
Roland
Avatar de Roland
lo otro.. hay toyota dyna 4x4 con portals???
Si hay toyotas dna 4x4 y vienen todas con portals..... pero en Chile no he visto ninguna todavia.
Antiguo 02-08-2007, 18:34:51   #15
AndR3Z
y seran compatibles esos portales con los ejes toy 8 ????... empiezo a sentir el cosquilleno de necesidades
Antiguo 02-08-2007, 19:05:43   #16
En chile no hay, solo en Australia, Japon.
me parece que el diam. de la corona es de 10 o 12". El Dyna que tengo, es de 10.
Antiguo 02-08-2007, 20:15:50   #17
piraña
Avatar de piraña
andrez busca bien en las paginas que te di ahi encontraras lo que necesitas saber, no solamente las listas que te di
Antiguo 02-08-2007, 21:01:23   #18
AndR3Z
toy encontrando harta info
por lo visto los cabeza de pig son iguales, lo mismo q los portales
al menos de distintos ejes tienen los mismos codigos de piezas
parece q cambian las coronas, mangas y palieres no mas
Antiguo 02-08-2007, 21:10:17   #19
Ricardo Montory
a ver,para hacer la historia mas simple en chile puedes encontrar 3 tipos de diferenciales los de 411,404 y los diesel 406,416 y 426,estos ultimos son los mismos, los dif.de los diesel son partidos,en la corona,los de 411 y 404 son relativamente parecidos, pero no iguales,el 411 es mas angosto que el 404. generalmente todos los injertos se hacen con el 404 a excepcion del piraña que utilizo los de 411.
Ricardo Montory está offline   Responder Con Cita
Antiguo 03-08-2007, 22:20:51   #20
http://www.killeraxles.com/10.html
La franja horaria es GMT -3. Ahora son las 19:26:24.
